Step 1: Update to Latest Firmware
- From homescreen 1, press on right arrow to get to homescreen 3 and press Update Firmware icon
- Install firmware update (if applicable)
- You will see a notification confirming that your firmware version is the latest available
- If a firmware update is needed, your device will power off and restart once the update is complete
• Press Toner Delivery Settings icon Homescreen 1
• Press Toner Delivery Settings: Deactivated Homescreen 3
*Placement or actual screen may vary
Step 2: Activate Auto Replenishment Service
Follow on-screen instructions if prompted. If a prompt does not appear, follow instructions below.
• Press Toner Delivery Settings icon Homescreen 4
• Press Accept to continue
• Press Activate to begin setup
• Press Next after reading first validation step
Step 3: Final Validation Steps
Next, you should see screen validation below
- Press OK
- Check server connection status. You should see the following Server Connection Status: Successful screen.
If an error message occurs, follow on-screen instructions
